Aprilaire 600 wiring with a Payne HK42FZ013
Old 02-15-13, 07:44 AM
T
Hello all, I hope someone can help me out. I am trying to install a Arpilaire 600 humidifer but can not seem to figure out the wiring. I am putting it in test mode but the water never flows. I have a Payne Furnace with a HK42FZ013 contol board. Here is how I currently have it wired:
R ---- R
C ---- Com 24V
A ----
B ----
ODT ---- outside temp sensor
W ---- W
G ---- G
H ---- Water Solenoid and also HUM on furnace
Gf ---- G
If anyone can tell me where I have gone wrong I would appreciate it! Thanks, -- Tim
Old 02-15-13, 07:51 PM
Jay11J's Avatar
The G, is the wire itself going to it from the t-stat, and Gf from the humidistat going right to the G on the furnace?
Hum from the furnace (Is that 24 volts???) going to one of the H. one wire from the solenoid valve goes to the other H. The other solenoid wire goes to C.
Old 02-16-13, 08:55 AM
T
I have the G and Gf from my humidity controller both going to G on the furnace control board. From my t-stat there is a G and the green wire comming out of that also goes to the G on the furnace (so total there are now three wires going to G on the furnace). Is that how it should be?
From my furnace manual it say the HUM terminal is 24-VAC 0.5 AMP MAX. So I need to change my H's to this:
H --- HUM on the furnace board
H --- solenoid
C --- solenoid and Com 24V on the furnace board?
Thanks! -- Tim
Old 02-16-13, 01:24 PM
Jay11J's Avatar
The green wire from the stat goes to G at the huimdistat. The Gf will go to G on the furnace, so just one wire on G.
Correct on the C and H hook up.
Old 02-17-13, 04:24 PM
T
I wired it like you instructed and it is now working good. Thanks for your help Jay! -- Tim
Old 02-17-13, 08:38 PM
Jay11J's Avatar
Thanks for the update, and glad to hear it's working.
HTML code is On
