Generalaire Flow Through Humidifier - Operating Questions and Humidity Issues
Received 0 Votes
I had the Generalaire 1042 series installed with the Generalaire MHX3 humidistat. I am a bit confused on its operation and am hoping you all can help me out.
1) It has a dial humidistat that goes from "Off" --> 10 --> 75 --> "On". The manual recommends setting the humidistat at a lower percentage the lower the outdoor air temp is. Ex: -20 F = 15% and +30 F = 40%. The setting seems counterintuitive. Logically, I want to set it at 50% (as in to say stay on until indoor humidity equals 50%). But am I correct that based on recommended settings I should be setting it much lower, say 20%, which tells the humidifier to kick on when what happens exactly?
2) I have had it set around the 45% mark, which based on recommended settings of 40% when it is +30 F is about right, but indoor humidity is staying down around 26%. Right this moment it is 33 degrees outside, 49% outdoor humidity, and 26% indoor. I have had the humidifier set on 45% for a week and nothing has changed. I just don't know how to get the humidity up.
Thanks for the help
Thanks for the help
Welcome to the forums.
What happens when you put the humidistat in on mode ? Does humidity rise ?
With the humdistat in on mode it will run continuously when the fan runs.
