TrueEase HE250 + Nest Wiring + Trane XV90
Old 12-07-13, 07:02 PM
D
Hello all,
I want to hook up a Honeywell TrueEase HE250 to my Nest and my Trane XV90. I wanted to confirm the wiring diagram.
I won't be connecting an AFS (air-flow switch) since the nest is smart enough to figure that out.
And where should I get 24V (15VA)? From the furnace or from a separate transformer? I want the humidifier to run with fan + heat or just fan.
Thank you!
PS. The original image is attached and was taken from here:
https://customer.honeywell.com/resou.../69-2413EF.pdf
Old 12-08-13, 02:08 AM
Received 1,113 Votes on 1,033 Posts
The wiring diagram is ok.
To be safe.... a separate 24vac transformer is suggested.
Old 12-08-13, 02:57 PM
D
Awesome. Thanks PJ. Out of curiosity, do you know why they had a common wire on the humidifier side? (Original diagram)
Old 12-08-13, 03:07 PM
Ummm.... you sort of lost me.
A common connection is needed as well as the * from the Nest.
Old 12-09-13, 09:44 AM
D
Ok. Sorry about that
So I attached two pictures to my original post:
The first picture is the picture I made that has the Nest on it.
The second picture is the original picture from the manual (no Nest). My new question is about this second picture. It has a wire going to the "EQUIPMENT" C terminal on the humidifier. I assume it is a common but I can't figure out what it is for and if I need it. I have reattached this picture below with the wire in question circled in red.
Name:  Screen Shot 2013-12-07 at 7.12.29 PM.jpg
My only guess is that it can act as a switch if the air flow sensor (AFS) detected air flow. But I won't have an AFS so I assume I can just leave that "EQUIPMENT" C disconnected. So my question is, is that "EQUIPMENT" C important for my setup? Or can I leave it disconnected like I was planning?
Old 12-09-13, 09:52 AM
D
To further clarify here is a picture with the Nest and the EQUIPMENT C terminal hooked up.
So to reiterate, my question is, can I get rid of that wire? (If it has to be there, what does it do?) (See post #5 for the picture the Honeywell manual has... it's possible I drew that wire in the wrong place.)
Old 12-09-13, 10:07 AM
I'm pretty sure that common is only needed if you use any of the other connections in the "equipment" box. That would be like R and C or G and C. You aren't using those connections.
Hope I didn't confuse the issue.
Old 12-09-13, 10:47 AM
D
I think you are exactly right. I just remembered that the manual gives a description of those terminals. Here is what it said:
C: Common. Needed for Gt or W input. Connect to system C.
So for future reference, this is the set up I will be using for the Honeywell TrueEase HE250 with my Nest.
I seriously doubt I'll have any problems, but if I do, I'll report back.
Thanks a million PJ.
Old 12-20-14, 10:26 AM
R
Did this work for you? I need to connect the same humidifier to an ecobee3 thermostat which has a similar wiring configuration as the Nest. Having a hard time. I am going to try your setup. Did you use the external transformer to power the unit or are you using the furnace to power the he250?
Old 12-20-14, 10:50 AM
There are several variations of the above diagram that will work. The one posted here will work fine. I highly recommend using the separate transformer for the HE250.
If you were set on using the furnace transformer then it needs to be a 40 watt model or larger.
HTML code is On
