Honeywell HE240 new install... not working
Old 01-02-14, 06:41 AM
Yesterday I tackled installing a new humidifier to my furnace (Lennox G40UH). All went well until I tried the system out. I cant seem to get the water solenoid to activate. I checked and double checked wiring and such. Although I haven't metered the wiring yet.
From looking here and a few other spots online. It seems that my pressure switch isn't activating. When I turn my humidistat knob I can here the relay "click". So I'm thinking that it is working correctly.
Is there anyway of forcing the pressure switch to activate?
Here are some pics of install...
-Ryan
Old 01-02-14, 08:05 AM
Jay11J's Avatar
Was the furnace running?
I can't really see in the photo, how do you have the pressure switch hoses hooked up?
Old 01-02-14, 08:13 AM
Yes furnace and blower were running. I tried to check it over a couple hours and still had not seen any water in the filter and/or drain.
One thing I was thinking about. My hose to the pressure switch isn't perfect from when I opened it in the package. There was a couple almost collapsed spots in the hose. When I take that hose loose. I can barely feel air coming through. I may try just changing out that hose and see if i can get more air flow?
Old 01-02-14, 08:20 AM
Jay11J's Avatar
Did you make sure you turned the water on?
Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Old 01-02-14, 08:32 AM
Thanks. I am gathering things to test out this evening. I will reply back then and see what I come up with.
Old 01-02-14, 05:56 PM
That was simple. Forgot to make sure the bottom outlet has power. The tab was broke off the receptacle I put in for the humidifier. Works great now.
Old 01-02-14, 06:52 PM
Jay11J's Avatar
Glad it was a simple fix, and thanks for the update!
Smilies are Off
HTML code is On
