Nest wiring to humidifier
Old 04-18-14, 02:50 PM
F
Hi,
I have an Aprilaire 550 and I want to wire my Nest 1st Gen to it. My Nest is currently operating my Rheem furnace without any issues. Can someone help me with how to wire it? When does a relay come into play? I have attached a diagram of the current setup.
Thanks,
Doug
File Type: doc
Old 04-18-14, 05:42 PM
Received 1,109 Votes on 1,029 Posts
I see your diagram.
I'm assuming that transformer is wired to the HUM terminals on your furnace control board... correct ?
It would be helpful to know the make and model of your furnace.
You will also need one additional wire between the thermostat and the humidifier/furnace.
Old 04-19-14, 07:54 PM
F
I just checked and one wire is connected to neutral and the other I believe is going to ground (can't really tell as it's connected to a plug). This is a Rheem Classic Super Quiet 80. Nothing is hooked up to my HUM terminal.
Thanks,
Doug
Old 04-20-14, 10:30 AM
Ok... so it's plugged into an "always live" receptacle.
I would use a basic 24vac normally open relay to do what you want. It would use that transformer and the Nest would activate the transformer.
Does that nest have the multi purpose * output connection like the version two does ?
Did you locate a spare wire from t'stat to furnace for the * connection ?
Old 04-20-14, 07:40 PM
F
The 1st Gen only has a Aux/W2 connection. I believe only the Nest 2nd Gen can be hooked up to a humidifier. I have a 2nd Gen on the first floor I can swap out. Can you sketch a diagram for me so I can get a better understanding on how to wire this?
Old 04-20-14, 08:29 PM
Your diagram...... redrawn.
Old 04-21-14, 07:18 AM
F
Thanks! I will give it a shot. Can you point me in the direction on which relay to purchase?
Old 10-03-15, 07:16 PM
F
I'm revisiting this project and was wondering if I can just connect connect it this way without using a relay. Will the nest provide enough voltage to activate the solenoid on the humidifier?
Nest * connection --> 1st hum solenoid wire
C terminal on furnace ---> 2nd hum solenoid wire
Thanks.
Old 10-03-15, 07:37 PM
I had to go back and re-read the thread. Been a while since you've been here.
Yes.... the nest has enough oomph to run the humidifier. It's more about the size of the transformer that is running the furnace. Worst case...... you'll need to upgrade to a 40va transformer if that one fails.
HTML code is On
