Nest 2.0 to Trane ThumD200 Bypass Humidifier
Old 06-02-14, 10:41 AM
Hello all! I have installed a new Nest 2.0 to my XV95 furnace and it's working great. However, I'd like to get some help connecting the Nest 2.0 to my Trane ThumD200 Bypass Humidifier. Currently the humidifier is connected to an old humidistat that is in the hallway where the Nest is. I've put together a diagram of the current setup....
Old 06-03-14, 09:30 AM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
You are going to need an extra wire from the nest to your furnace that will run the humidifier.
Old 06-04-14, 06:58 AM
So after digging around the forums I drew this up and wanted to verify it's correct or not?
-Remove w1 at the furnace.
-C from furnace to either wire at humidifier and on to nest C connection
-Other wire at humidifier to nest * connection
Old 06-04-14, 08:28 AM
Thumbs up
Your diagram is correct and will work.
Old 06-04-14, 08:48 AM
Thanks for your help PJmax! There's a lot of crazy information out there so I appreciate the verification
Old 11-17-14, 11:23 AM
G
sstavin,
Did this work? That is exactly my setup and I had read other places that I would need to wire in a relay. If that works it is much more simple, and easy.
Old 11-17-14, 09:38 PM
Yes..... that is a basic hookup and will work.
You would use a relay if you needed to use a second transformer to power the humidifier.
HTML code is On
