General humidifier wiring
Old 11-15-14, 11:04 AM
E
I have a carrier humidifier on my furnace. It would not start up this year, solenoid was replaced. i want to double check wiring. The power from the furnace is connected to one wire of the solenoid. The other solenoid wire is connected to power wire of the humidistat. The ground from humidistat is connected to ground from power source. This seems to say that when the humidistat senses that it needs humidity, the circuit is broken causing the solenoid to open. Does that sound right.
john
Old 11-16-14, 10:22 AM
Received 1,110 Votes on 1,030 Posts
Power from the furnace ? ? Doesn't tell us anything. Where is it connected inside the furnace ?
Basic humidifier setup....
HTML code is On
