Humidity
Old 11-23-14, 01:41 PM
Geochurchi's Avatar
Received 72 Votes on 68 Posts
Humidity
Hi All, what creates humidity in a closed up condo i.e one in Naples Fla. There are no showers taken,no cooking,unit is well insulated with new high impact windows all around.
Geo
Old 11-23-14, 01:49 PM
XSleeper's Avatar
Received 666 Votes on 616 Posts
Probably no fresh air exchange... no air conditioning. Houses on concrete slabs with concrete walls absorb moisture from the ground and air.
Old 11-23-14, 02:01 PM
Just because you have "high impact" windows, that is no guarantee about holding off the exterior humidity (about 2/3 of all windows are not installed properly). The windows themselves could leak air also.
I have friends that "abandon" their Florida condos in the summer, but they leave the air on and set to a high temperature to operate once in a while to eliminate the excess humidity and odors that can linger and show up when the unit is opened up again.
Dick
Old 11-23-14, 02:35 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Any gas fired appliances can also generate some humidity even when properly vented. Power vents not so much AFAIK.
Old 11-24-14, 02:53 AM
Received 316 Votes on 280 Posts
Fla has high humidity to start with and if the condo is closed up without the HVAC running the humidity has nowhere to go.
HTML code is On
