Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Humidifiers and Dehumidifiers
Reload this Page >
Aprilaire model 60 control not working in test mode or when humidity level set
Old 12-02-14, 10:17 AM
F
This model 700 Aprilaire humidifier with model 60 control worked fine two winters until this one. I installed a new control and new temperature sensor which did not solve the problem. With blower activation switch off and furnace running: Turning knob to test position the green light flashes and then 3 blue lights flash but the water never flows through the solenoid and the humidifier fan does not run and error code r1 appears.
With blower activation switch on and furnace running or not running: the solenoid valve clicks and water runs and humidifier blower runs. But I do NOT use it with the blower switch on and it is not wired for that feature.
If I set the unit for manual operation it will not operate at all with blower activation switch off but will with blower activation switch on. It will control the water solenoid with the humidifier knob and when the furnace shuts down the humidifier blower shuts off but the solenoid for water stays on.
What could the problem be? The wiring to the humidifier control is the same as the previous control. The furnace circuit board was changed last February by my dealer but I can not recall if I ran the humidifier after that occurred.Name:  2014-12-02 13.15.30web.jpg
Size:  42.3 KBName:  2014-12-02 13.14.45web.jpg
Size:  27.0 KBName:  2014-12-02 13.16.15web.jpg
Size:  16.3 KBName:  2014-12-02 13.16.43web.jpg
Size:  34.6 KBName:  2014-12-02 13.14.34web.jpg
Old 12-02-14, 06:25 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
When I wire the model 60 I only use a connection to the W terminal for activation. I don't use a G connection at all. Using the W connection only allows the humidifier to work in heating mode only.
Name:  700A humidifier.jpg
Old 12-03-14, 10:20 AM
F
Tried Removing G terminal wire
Today I removed the G terminal wire at the Aprilaire 60 control and the humidifier acted the same as previously described. I traced the W terminal white wire back to the furnace panel and I see it is connected to a W2 terminal. A different white wire (not from Aprilaire 60 control) is connected to the W1 terminal. I am guessing that this has to do with the 2 speed blower this furnace has. Normally it runs at a lower speed all the time but as it gets colder it will occasionally speed up temporarily to blow more heat around the house. Should the humidifier control be connected to W2?
Old 12-03-14, 10:19 PM
Move the W wire to W1. That should take care of the problem.
Old 12-04-14, 10:43 AM
F
I moved the W wire to W1 in the furnace panel and that fixed the problem. Thank you so much for the help!
HTML code is On
