Aprilair 800 wiring
Old 12-07-14, 06:24 AM
O
Unhappy Aprilair 800 wiring
I am trying to get my aprilair 800 to work with my geo system. Problem is the wiring calls for a W wire from the thermo. I have no W wire from my thermostat. My system is a two stage compress with a O wire to determine heat or cold)
Y2 = compressor 2 relay
Aux/E aug/emerg heat
Rc joined to R = power
O/B = changeover
Y= compressor 1 relay
G = fan relay
C= 24VAC common
I think, but have not done using the Y , but that is both both cold and hot
using the ADHC model 62
Old 12-07-14, 06:55 AM
Houston204's Avatar
Received 17 Votes on 14 Posts
Post the complete model number and the make of the Geo unit for better assistance.
If your stat has separate O and B terminals you can connect stat B to a relay coil to only allow humidifier operation in heat mode. Wire the humidifier control wire through a set of normally open contacts on this new relay.
Old 12-07-14, 07:35 AM
O
stat has either O or B selectable by installer. Not seperate.
But O/B normally open on heat
Old 12-07-14, 07:54 AM
Houston204's Avatar
What is the make and model of the geo unit?
Many units have a terminal for the use of a humidifier. If you post the model number we may be able to look this up.
Many posters use things like "E series" for a model but we would need the complete model number to bring up your diagram.
Old 12-07-14, 07:57 AM
O
Florida heat pump AP035 -1VTC
Y2 = second stage compressor
Y1 = First stage compressor
G = fan relay
O = reversing valve (energized in cooling)
W1 = Aux heat ( electric + compressor)
Em/W2 = emerg heat (electric only)
NC = Transformer 24 v common (extra connection)
C1 = transformer common (primary connection)
R = transformer 24V hot
HUM = Dehumidification Mode
Old 12-07-14, 08:27 AM
Received 1,113 Votes on 1,033 Posts
Looks like the Florida line is manufactured by Bosch now. Not much online in servicing info.
Old 12-07-14, 08:37 AM
O
might work
the idea of an extra relay might work if the relay were normally closed. Then when cool is called for it would open. Only issue is if i turn the fan on in heat mode the humidifier would come on.
is there a different stat i can get that would work?
Old 12-07-14, 08:49 AM
Houston204's Avatar
http://www.fhp-mfg.com/files/downloa...stallation.pdf
I see a manual for this FHP AP035 but the Hum terminal is for dehumidification.
The relay will work if you use the O terminal and wire your humidistat through a set of normally closed contacts as you have posted.
Name:  FHP AP035 to AprilAire 800.jpg
Old 12-07-14, 09:14 AM
O
thanks for the assistance..
Old 12-07-14, 09:22 AM
Houston204's Avatar
The Honeywell Prestige IAQ would be able to control humidification and dehumidification.
It only requires 2 conductors between the stat and an equipment interface module that you install by the geo unit.
It would be a better option since my diagram would only lock out the humidifier in cool mode not when heating has cycled off. An additional relay with Y and C to the coil and the humidistat wired through a set of normally open contacts would also be required to lock out the humidifier when the compressor is not running.
Name:  FHP AP035 to AprilAire 800 2 relays.jpg
Old 12-07-14, 10:37 AM
O
lots of food for thought.. These are great, and probably the only solutions. I will have to get someone more advanced then me to implement them. Thanks greatly.
I did try turning on the A/C to see if the system would at least start to work. I did start to filling the canister. Not sure that proves anything though. Too cold here to leave on for long.
thanks again. At least i know there is a solution.
HTML code is On
