Installing aprilaire model 60
Old 12-09-14, 06:42 PM
V
I have a Carrier 93% efficiently furnace with an aprilaire 600 humidifier. It's currently hooked up to a manual humidistat and I want to change it to an automatic humidistat using the aprilaire model 60. I have a few questions about the change over....
1. The wiring looks like it should work however, I currently don't have a separate 24v transformer. It's getting all it's power from the control board in the furnace. Do I have to run a separate transformer? Or can I just use the one on the furnace. I will only run the automatic humidifier when the furnace is on.
2. Can I install an automatic temperature probe in my PVC intake pipe. My intake and exhaust are exiting through my roof hence the furnace is on the second floor of my home.
Thanks in advance....
Old 12-09-14, 10:48 PM
Received 1,104 Votes on 1,024 Posts
Welcome to the forums.
The diagram below allows you to use the furnace transformer to run the humidistat and the humidifier. You should confirm that your furnace uses at least a 40 watt transformer.
The temperature probe needs to be outside.
Old 12-10-14, 06:32 AM
V
PJmax,
Thanks for the schematic. I'll check on the 40 watt transformer.
I thought I read somewhere I could mount my temperature probe
In my cold air intake pipe. If not, do you recommend I mount it
To come out of my exterior soffit on the second floor. That part of
My house faces east.
Thanks
Old 12-10-14, 09:20 AM
I've never mounted the sensor in the return line so you are on your own there.
Exiting at the second floor soffit would be fine.
Old 12-10-14, 03:18 PM
V
Ok, thanks for all your help. This site is awesome!!!
HTML code is On
