Aprilaire 700 installation question
Old 12-14-14, 08:36 AM
B
I'm looking at buying and installing a Aprilaire 700 humidifier, but I have run into a bit of a stumbling block.
All the supply and return ductwork is fiberglass duct board, so I have no solid metal anywhere to properly mount the humidifier.
What are my options or do I have none?
Old 12-14-14, 09:57 AM
Tolyn Ironhand's Avatar
Received 211 Votes on 187 Posts
Not an HVAC pro but could you replace some of the fiber duct with metal?
Old 12-14-14, 12:01 PM
Norm201's Avatar
Received 234 Votes on 209 Posts
I'm also not an expert, but I think you should be able to rivet metal strips to make a frame of sorts on the inside surface of the plenum. Then screw the unit to it.
HTML code is On
