Aprilaire 60 to Trane heatpump
Old 12-31-14, 11:33 AM
P
Hello. I have a Trane Variable Speed heat pump in which I am attempting to hook up an Aprilaire 60 humidifier control. I currently have everything hooked up and ready to go except for where to hook up the R and C leads to on the furnace control board. There are no R and C terminals on the control board. Only have G, O, B, B, Y, W1, W2 and W3. I just need to find out where to hook up the R and C leading from the model 60 to the control board? Any help to get some humidified air in to our home certainly would be appreciated. Thanks.
Old 12-31-14, 11:26 PM
Received 1,105 Votes on 1,025 Posts
Welcome to the forums.
Two B's ?
The wires you need to look for will be inside the air handler. Can you post the model number of your air handler or even a picture of your control board or the board part number.
Old 01-02-15, 01:39 PM
P
The model number is 4TEE3F31A1000AA. If you could send me over a picture of how this unit should be correctly wired up with the provided model number that would be awesome. Thanks for your help.
Old 01-03-15, 12:03 AM
I'm looking into it now. This is a high end Trane system and looks to be a communicating one.
I want to see what my partner Houston thinks too.
Which humidifier are you going to be using ?
Old 01-03-15, 08:52 AM
P
I will be using an Aprilaire 600. Thanks.
HTML code is On
