Aprilaire 60 humidistat & Goodman GMH95 furnace
Old 01-23-15, 01:25 PM
Hi everyone,
I hope you all can help me a wiring an Aprileaire 60 humidistat.
I am installing an Aprilaire 500 bypass humidifier with the 60 humidistat. I have a Goodman GMH95 furnace.
I am done with all the mechanical stuff, but the wiring part really has me puzzled. Even after reading a lot of threads all over the web, I am still stumped! I will admit that I am pretty dense when it comes to electrical-type stuff and I really hope you guys can help me out...
So far, I've done the following:
(i) mounted the transformer on a junction box that turns the furnace on and off
(ii) connected the R and C on the humidistat to the R and C from the furnace.
(iii) connected the W on humidistat to the W from the furnace.
(iv) connected the two H terminals from the humidistat to the transformer and solenoid valve on the humidifier (H1-transformer-yellow wire, H2-yellow wire)
(v) connected the wires from the outdoor sensor to the ODT terminals on the humidistat
The problem is that the humidifier doesn't come on, even when I put it in the test mode.
Am I doing something obviously wrong or stupid? What specific voltages can I check to make sure that the wiring is correct?
I would greatly appreciate any help. Thank you!!!
Old 01-23-15, 01:42 PM
Received 1,118 Votes on 1,038 Posts
Welcome to the forums.
I've posted my tried and true wiring that should be how you are wiring.
Does the humidistat light up ?
No.... check for 24vac coming from the furnace on R and C.
If it does light up.... check your new transformer for 24vac.
You need to measure 24vac on the humidifier solenoid.
Name:  500A and 600A.jpg
Old 01-23-15, 06:53 PM
Thank you, PJMax! My wiring was just like in your diagram.
After I got home, I re-checked everything, and there was a loose connection at one of the H terminals. Phew! I fixed that and now everything works like it's supposed to.
Thank you again.
Old 01-23-15, 07:36 PM
You're welcome............ great news!
HTML code is On
