Wiring an Aprilaire 600M to a Lennox CBWMV
Old 01-24-15, 11:59 PM
R
Hello,
Having some difficulty wiring an Aprilaire 600M flow through bypass humidifier to a Lennox CBWMV. Any input would be greatly appreciated.
Aprilaire 600M installation instructions (PDF):
http://www.aprilairecontractor.com/p...iers/83266.pdf
Lennox CBWMV Owners Manual (PDF):
https://www.lennox.com/pdfs/installa..._CBWMV_IOM.pdf
Pages 10 - 13 from CBWMV owners manual:
Pictures of the board:
Old 01-25-15, 01:22 PM
Received 1,109 Votes on 1,029 Posts
Welcome to the forums.
One question.... It looks like a heat pump setup with a hot water coil for heat ?
If it has a coil.... is that primary heat ?
Old 01-25-15, 01:41 PM
R
Hello PJmax,
Its a hydronic air handler with a hot water coil as the only heat source.
Old 01-25-15, 03:22 PM
Is there an A/C condensor involved with the system ?
I see the relay is installed. I have a few questions.
1) Confirm my labeling of the board is correct.
2) Cable B is the thermostat.
3) Is cable A and D the same cable ?
4) Where does cable C go to ?
Old 01-25-15, 04:05 PM
R
No, there is no a/c condenser involved, it is heat only.
The labelling is correct.
Cable B is for the thermostat.
Cable A and D is the same cable.
Cable C goes to the boiler.
HTML code is On
