Nest 2.0 + Honeywell HE360 + Relay
Old 01-31-15, 11:31 AM
D
Hello all! I have been reading various posts and have saved down many diagrams and other pictures that you all have posted as I prepare to wire my Honeywell HE360 humidifier to my system. I wanted to get some input on the relay that I have and see if it would work, and if so, how I would wire everything properly.
I also want to confirm that I can wire everything together without using the provided humidistat and instead just wire directly to the Nest.
I picked up a White Rodgers 90-293Q a while back but now it looks like that relay might not be the right one. If it will work, how is it wired?
Any questions on anything or if I need to post any pictures, let me know!
Thanks,
Dustin
Old 01-31-15, 12:50 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
The 90-293 is just a double throw relay..... it'll work fine here.
Old 01-31-15, 04:15 PM
D
Awesome! That helps a lot and I'm glad that relay will work. Is this diagram pretty much what I want to do to get the Nest to control the humidifier?
[ATTACH=CONFIG]45846[/ATTACH]
Thanks!
Dustin
Last edited by Dustin Bates; 01-31-15 at 04:16 PM. Reason: Changing attached image.
Old 01-31-15, 04:28 PM
Looks you are in pretty good shape there.
Old 01-31-15, 04:33 PM
D
Thanks! I'll reach out if I seem to have any trouble. I appreciate the help!
Old 02-01-15, 01:07 PM
D
Ok, so I guess this might be more complicated than I thought. At least for me! Trying to piece together how I am supposed to wire everything using a chart like the one below. Here's what I put together for my system so far:
Name:  Furnace Wiring.jpg
What I'm trying to do now is figure out what all of the wires inside of the furnace should be connected to. I have a couple of pictures of the wiring and can provide more details if necessary. Hoping that I can sketch something up that will tell me which wires to connect to what and it's not too difficult.
Name:  2015-02-01 15.17.16.jpg
Name:  2015-02-01 15.17.31.jpg
Name:  2015-02-01 15.17.52.jpg
I was hoping to use the diagrams I found on here for other systems to help guide me, but it looks like I don't know enough to just convert the wiring for one system to another confidently. Any help would be appreciated!
Just let me know what else I need to figure this one out (if anything).
Thanks!
Dustin
Old 02-01-15, 01:47 PM
Is the nest currently installed ? If not....
Look at the current thermostat. Post the model number and what color is on each screw terminal.
Old 02-01-15, 01:53 PM
D
Yes, the Nest is already installed and here is the way it is wired:
Name:  2015-02-01 15.23.35.jpg
Old 02-01-15, 05:38 PM
D
Here are a few additional pictures just in case.
Name:  2015-02-01 16.58.03.jpg
Name:  2015-02-01 16.56.57.jpg
Name:  2015-02-01 16.56.51.jpg
Name:  2015-02-01 16.56.25.jpg
Name:  2015-02-01 16.56.14.jpg
Name:  2015-02-01 16.56.00.jpg
Old 02-01-15, 06:10 PM
So..... your question is how to wire the humidifier ?
You need an extra conductor from the thermostat to the furnace. That wire will be dedicated from the * terminal to the relay coil. The other relay coil contact gets connected to the same place your blue thermostat wire connects to.
Old 02-02-15, 04:37 PM
D
Ok, I follow now. I was making it a bit more complicated than it needed to be I guess! I appreciate the help, Pete!
HTML code is On
