Can I install Aprilaire 600 on return duct?
Old 02-11-15, 09:44 PM
H
Ok. I might have a few more questions since it's my fisrt time doing it.
But, first off, I got Aprilaire 600 bypass model.
The manual says attach it on Supply side. But there is not enough sapce on my furnace duct.
Can it be installed on return duct?
Thanks.
I wish I could upload some pictures but somehow I cannot, it keep saying failed.
Old 02-12-15, 12:34 PM
Received 1,113 Votes on 1,033 Posts
Failed picture loading usually means the pictures are too large. The board will accept up to 100kb sized pictures and then resizes them to a board maximum of 50kbs. You can post them at any free hosting site like photobucket or Imgur, etc. and then link to them here.
Most bypass models can be installed either way. So can the Aprilaire 600.
Directly from the installation manual.....
Old 02-15-15, 02:22 PM
H
Is there enough space?
Old 02-15-15, 02:25 PM
Is that a patch plate over the top of the furnace ?
Looks like one may have been there at one time.
Old 02-15-15, 03:43 PM
H
After duct cleaning, they put the patch at top and bottom.
Sorry for the drawing, but would it be right?
Old 02-15-15, 07:43 PM
If the cut out is the correct size that would be a viable location.
Old 02-20-15, 06:24 PM
H
The duct is not fitting on that cut out part.
How about doing this way? connect bypass duct at top?
Does it matter? or have to be connected on side?
Old 02-21-15, 07:16 AM
I've never tried it like that but it should work ok.
Old 02-22-15, 08:28 AM
P
I'm going to have to install mine like this too. Just make sure your controller is at least 6" upstream from the humidifier, so that the humidity sensor is not affected by the humidifier.
I don't have any room on my supply side to mount it. I have a feeling it might work a little better on the supply side though, since the air will be warmer and help evaporate more water from the humidifier.
HTML code is On
