Clicking noise from Honeywell humidifier
Old 03-12-15, 06:12 PM
D
Hi, Had my Honeywell HE240C humidifier installed just over a year ago. So this was its second winter. I am now hearing a fast clicking noise when the humidifier kicks in. It seems to be coming from the solenoid area.
Any ideas out there?
Separated from...
http://www.doityourself.com/forum/hu...t-working.html
Old 03-12-15, 08:13 PM
Received 1,119 Votes on 1,039 Posts
I gave you a thread of your own so that the repair is aimed directly at your problem.
You may have a problem in the pressure switch activation system.
Do you have small tubes drilled into the ductwork ?
What are you using for a humidistat ?
HTML code is On
