New Aprilaire 760 Problem
Old 03-16-15, 09:44 AM
E
Have the subject humidifier where the fan doesn't run. When the humidistat is set to max, water flows but the fan doesn't run. There is a loud buzzing noise coming from within the case. I might venture a guess that is a rapidly engaging and disengaging relay, but I'm not sure. The fan motor was replaced recently. Any suggestions?
Old 03-16-15, 10:02 AM
Received 1,110 Votes on 1,030 Posts
Welcome to the forums.
You mentioned new.... what's new.... the entire unit ?
That unit has a relay and a transformer in it so either one can cause a buzz but the relay would be louder. What humidistat are you using ..... manual or automatic ?
There should be two wires coming out of the humidifier and heading to the humidistat. Short them together and see if the buzz stops and the unit operates normally.
HTML code is On
