Installing a Nest thermostat with whole house humidifier?
Old 04-13-15, 10:54 AM
Q
I just bought a v2 Nest thermostat to install in my newly purchased home. It has a High-efficiency gas furnace with a heat pump for AC. Also, there is an older Totaline humidifer attached to the furnace. Nest provided a wiring diagram for everything but the humidifier.
My question - How do I connect the humidifier to the Nest? Can I just attach the humidistat wire to the Nest's * port, and then program it?
Thanks for the advice!
Old 04-13-15, 08:20 PM
Received 1,103 Votes on 1,023 Posts
You may need a relay to connect the Totaline humidifier.
Is there a model number on the humidifier ?
HTML code is On
