What are these?
Old 06-11-15, 02:47 PM
R
What are these?
I just bought a house and want to add a humidifier to my AC unit. (We actually have two units). I wasn't sure what these are, but thought they might be built in humidifiers?
Old 06-11-15, 03:48 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Welcome to the forums! No, they are condensate pumps that turn on when they get full and evacuate the water/condensate to the outside of the house or to a floor drain.
Old 06-11-15, 04:04 PM
R
Thanks. Thought I might have gotten lucky.
Old 06-11-15, 04:12 PM
R
By the way, will I need to install a humidifier per unit? Or can I just install one? It's a 3,100 square foot home. The upstairs and downstairs are on separate units. It's the desert, so it gets dry.
Old 06-11-15, 04:16 PM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
You will need one per system. Since you have two, the returns are probably in separate areas and not too much air mixing occurs.
Old 06-11-15, 09:01 PM
Received 1,109 Votes on 1,029 Posts
You want to add humidifiers for winter use..... correct ?
What do you have for heat...... gas or electric furnace or heatpump ?
Old 06-12-15, 07:54 AM
R
It's a gas furnace. Possibly two. I haven't moved in yet, but I'll stop by the house tonight and check. I mostly need the humidifiers for winter, but it also gets dry in the summer. Relative humidity here can drop down to 35% or so even in the summer.
HTML code is On
