How to address basement water pipe condensation issues?
Old 06-15-15, 09:41 PM
Q
Hello all,
I have found the basement water pipe is full of water drips and starts to form water puddle on the ground.
I saw some people mentioned 1> use foam wrap on all pipes 2> use dehumidifier.
Question> What is the best way to avoid the issue?
Thank you
Old 06-15-15, 10:19 PM
Received 1,109 Votes on 1,029 Posts
Anytime hot humid air hits something cold you'll get condensation.
The least expensive way to alleviate the problem is to use the split foam to cover the copper pipes.
Old 07-13-15, 09:06 AM
T
I have been dealing with the same issue the last couple of weeks. Foam insulation made no difference since the humidity was at 89%. The fix was to close off the vents, seal the crawl space as best I could and buy a dehumidifier. In just 1 week the humility dropped to 50% and crawl space is bone dry.
Old 07-13-15, 10:58 AM
airman.1994's Avatar
Received 8 Votes on 8 Posts
must reduce the humidity with a dehumidifier. 50-55%
HTML code is On
