Haier HDN655e control issue?
Old 06-30-15, 03:31 AM
P
Hi,
I have a Haier HDN655e dehumidifier that works fine except the temperature display always reads HI instead of the temperature and now the humidity display always reads 45% no matter if it is humid in the room or not. If I set the desired humidity to <45, then it runs fine.
I'm thinking it is either the humidity sensor, the control board or both. Any thoughts?
Joe
Old 06-30-15, 09:26 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
You mean it runs...... not runs fine since it won't shut off automatically.
It sounds like a control board problem. There is a temperature sensor and a humidity sensor. It would be doubtful that both went bad.
Old 07-02-15, 02:32 AM
P
I can't confirm if it will shut off or not since the place where it is located is quite large and I'm not sure it would ever get that dry. However, I can give that a try by putting another dehumidifier in the same space to see if it will shut off.
I tend to agree though, it doesn't seem like both sensors would go bad. The temperature has been reading "HI" for a while. The humidity reading has just started this summer.
Thanks!
HTML code is On
