Aprilaire 760 questions
Old 10-17-15, 12:49 PM
I have an Aprilaire 760 hooked up in my house. It has been unplugged since a new furnace was installed a few years back. I just cleaned everything out, put in a new filter and drain pipe. On the wiring front it has a manual humidistat.
It appears that the two wires on the humidistat run directly to the humidifier. As a result, when I turn the humidistat past the click point it runs continuously regardless of whether the HVAC system is running. This makes sense, as how would it know?
My comfortmaker furnace has a terminal labeled 24V HUM. Can I wire the humidifier in line with the furnace so it only runs when the furnace is running? Thanks.
Old 10-17-15, 03:10 PM
Received 1,105 Votes on 1,025 Posts
Hello neighbor.... a few towns away.
Your humidifier has it's own 24v internal transformer. You can't connect it directly to the furnace.
The following are the required connections. You'll need a 24vac relay. The board IS NOT your furnace but the connections are the same.... 24v HUM and Common.
Old 10-18-15, 05:33 AM
Thanks, I'll head to the Home Depot today to see if they have any. If not, Amazon.
Old 10-18-15, 06:41 AM
P.S. Any advice on how to set the water flow. I don't see much discussion on this online and I don't want to waste water. Thanks.
HTML code is On
