Connecting Humidifier to Zoned Nest with HZ432
Old 12-06-15, 09:29 AM
C
Hi,
Resurrecting this thread. I have basically a similar zoned setup (EMM-3 in this case), but, I'm only getting between 14.5 and 15.5 V across the C from the furnace board (not the zone control board.) and the * from any of my nests. This isn't enough to trigger the relay. When I apply 24V across pins 1 & 3 on the relay, I can hear it switch, so, the relay is working fine. Any ideas why I'm only getting 15V out of the C on the furnace board? I can try to tap into one of the C terminals on the control board that's feeding one of the nests (there are three zones).
Thanks in advance for any help.
Jeremy
Mod note: Moved from this thread: http://www.doityourself.com/forum/hu...ml#post2486425
Old 12-06-15, 12:33 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
You don't "get" anything from the C connection. The C is common.
You need to connect to the C from the same transformer that supplies the Nest. It's imperative to not mix power supplies. Since your stat connects to the EMM... the EMM is the C you should be using to the relay.
Old 12-07-15, 09:58 PM
C
thanks. I wired it to one of the C terminals on the control board and it's working great.
Old 12-07-15, 10:22 PM
Awesome.... good job. Thanks for stopping back and letting me know.
HTML code is On
