Nest with Humidifer
Old 12-06-15, 04:01 PM
Nest with Humidifer
Hello,
I just got a Nest and would like to add on my humidifier to it as well
The wires i have are R, G W, Y
Attached is how I have me Humidifier attached with my current T-stat.
I use a Aprilaire51 Current Sensing Relay, when the Blower starts and the Humidstat calls for humidity the Humidifier turns on.
How can I change this up so the Nest turns on the Humidifier?
thanks
Old 12-06-15, 06:12 PM
Received 1,109 Votes on 1,029 Posts
You can run the humidifier directly from the furnace provided the transformer in the furnace isn't overloaded.
Here's the diagram you need to follow. One wire from humidifier goes to C and the other goes to the * on the nest. Then the * function gets programmed in the stat programming.
Old 12-07-15, 04:36 PM
C Wire
Ok so I traced the C wire and it as well as the Y go off to the outside condenser. The Y has 2 wires terminated on it.
With that I shouldn't have to worry about overload correct?
thanks
Old 12-07-15, 07:19 PM
That's correct.....two wires now on Y and two wires now on C. Soon to be three wires on C.
C and * ....... not C and Y.
Old 12-27-15, 07:46 AM
update
Sorry for the long delay, had an issue with the Nest.
I have everything hooked up, question on programming the Nest with the Humidifier.
Do i select Hum. Heat?
Or just Hum.
Also Fan Activate?
thanks
HTML code is On
