400 series aprilaire humidifier not working
Old 12-07-15, 12:06 PM
R
My aprilaire humidifier is not getting any water. It has a manual humidistat. I checked the voltage at the two connections on humidistat and it's around 24v with the furnace running. I get no voltage at the connection to the solenoid. I've already replaced the solenoid, thinking that was the problem. Any suggestions?
Old 12-07-15, 03:55 PM
Received 1,112 Votes on 1,032 Posts
Welcome to the forums.
When the humidistat calls for humidity..... the switch closes and you should read 0v across it. It sounds like it's not closing. You can short those two wires to test the humidifier.
Old 12-09-15, 09:59 AM
R
Which two wires? The ones connected to the humidistat?
Old 12-09-15, 01:33 PM
R
Figured it out, jumped the wires connected to the humidstat. Turned on furnace and solenoid turned on the water to humidifier. New humidistat on the way.
Old 12-09-15, 06:40 PM
Glad you figured it out. You should be all set with the new h'stat.
HTML code is On
