Aprilaire 760 Control Board Gone Bad. Can you help me verify?
Old 12-19-15, 08:10 PM
D
I read 120 volts coming in from the power cord. I believe I'm supposed to read 24v coming off the leads that go to the thermostat. I read nothing.
That leads me to believe the transformer has gone bad and I simply need a new control board.
By the way nothing words at all. No fan, no water. Thermostat does "click" as it should.
I'm all set to order a new control board. Just want to verify that my readings do indicate that is what the problem is.
Old 12-19-15, 08:35 PM
Received 1,105 Votes on 1,025 Posts
Not thermostat...... humidistat.
This is one of the models where the company had the brilliant idea of using the same model number on a newer and an older version.
Does that board have a transformer on it.... like in the picture ?
Old 12-19-15, 09:03 PM
D
Yes that is it..120 Volts coming in from the left from the power cord. Measured OK. On the right I assume 24v should be coming out where it is marked humidistat. I am getting nothing.
Old 12-19-15, 09:49 PM
One of two things could cause that..... a dead transformer or an open coil on the relay. Either problem requires a board replacement.
HTML code is On
