Aprilaire 800 and Nest Wiring
Old 12-28-15, 09:20 AM
H
Post Aprilaire 800 and Nest Wiring
I plan on installing an Aprilaire 800 humidifier in the attic where the furnace is located, Carrier 58sta/stx - the home is two floors.
If the Nest (2.0) thermostat is located on the first floor, do I splice in the humidifier wiring in the attic with the use of a relay, like the 6AZU2 (or Emerson 90-290Q, which I purchased). No additional wiring down to the thermostat?
Thanks in advance!
Old 12-28-15, 09:34 AM
Received 1,103 Votes on 1,023 Posts
Welcome to the forums.
You'll need to follow the diagram below.
Old 12-28-15, 05:31 PM
H
Thanks! So nothing additional to wire to the thermostat, correct?
Old 12-28-15, 05:49 PM
Between the relay and the stat you need a wire for the *. If you have a spare... you're all set.
Old 12-31-15, 11:55 PM
H
Any chance you'd know the corresponding connections on a Rogers 90-290Q?
Old 01-01-16, 12:08 AM
1 and 3 are the coil (thermostat)
2 and 4 are the switch. (humidifier)
Name:  90290 relay.jpg
Old 01-01-16, 08:04 AM
H
You the man! Thanks again and have a happy new year!
HTML code is On
