Mounting humidifier over duct joint
Old 01-03-16, 08:21 AM
N
Angry Mounting humidifier over duct joint
I picked up a Honeywell HE360A for our house with the intention of installing it myself. I went with the 360 for the fan due to the size of our house, vs using bypass which I don't think would have worked very well. I watched the video, opened the box, grabbed the template and went to find a place to mount it ... and there only spot that it might fit is too short.
Knowing not much about furnaces, it appears I have a high boy. There is a section of duct work that is 3" shorter than the template that uses an s-cleat joint to connect to another piece of duct work that has all the outgoing connections. In order to install the humidifier I would need to cut through this s-cleat joint. (Annoyingly, you can see a sheet that's been screwed in just above this joint where a humidifier used to be.)
Is that bad? Should I just go for it and use some putty/tape to ensure there's not a lot of leaking? I have plenty of room for a bypass humidifier, but with a 3,000+ sq.ft. house, I'm not sure that's going to cut it.
Old 01-03-16, 10:30 AM
Received 1,104 Votes on 1,024 Posts
Welcome to the forums.
It's tough to mount a larger unit where there is a real estate shortage.
Just make sure the A/C coil is not behind it and try to mount the unit as level as possible.
Old 01-03-16, 10:44 AM
N
Sounds like I should just have at it then. There's enough real estate to mount it if it weren't for the s-cleat joint there.
Old 01-03-16, 05:11 PM
N
Follow up - went ahead and installed it, seems to be running just fine so far!
Old 01-03-16, 05:57 PM
Sounds like some good news.
HTML code is On
