Go Back  DoItYourself.com Community Forums > Heating, Cooling, Air Conditioning, Ventilation and T-Stat Controls > Humidifiers and Dehumidifiers
Reload this Page >
Aprilaire 800/Humidifier Control 60/62 with Trane Furnace Installation Question
Old 01-05-16, 08:53 AM
Hello,
I am trying to diy install an Aprilaire 800 (Steam Humidifier) with a Trane Furnace. In this process, I am required to connect wires between the humidistat and the Furnace of R, C, G, Y,W.
With that being said, I have the following questions.
1. I do not see a terminal labeled as "C" on my trane furnace, instead I see labels like, O, B, and etc, which one am I suppose to use for a "C"?
2. For W, I have three terminals, which terminal out of the three should I use to connect my humidistat?
Thank you in advance for all you help!
Old 01-05-16, 09:38 AM
Received 1,114 Votes on 1,034 Posts
On the Trane unit..... B is your C connection. I can't see all the terminals clearly to advise you on the W terminal.
HTML code is On
