Humidifier - Aprilaire 760 Not working
Old 01-05-16, 02:00 PM
Hi - I have an Aprilaire 760 humidifier that doesn't seem to be working.
The humistat is upstairs and I can hear it "click" on in the basement and the water is running. I don't believe the fan is running as I can only hear the furnace and water, but no fan.
What would you recommend I start? Do I just get a new motor or where do I start troubleshooting? Thanks!
Size:  23.7 KBName:  IMG_0784.jpg
Size:  25.0 KBName:  IMG_0785.jpg
Old 01-05-16, 04:31 PM
Received 1,110 Votes on 1,030 Posts
If the solenoid is allowing water to flow then it sounds like the fan motor has gone bad. You should disconnect AC power, open unit, check for 120vac to the fan motor.
The motor is an Aprilaire 4237.
Old 01-06-16, 05:58 PM
Hi PJ -
so very stupid question, if the humidifier is completely unplugged, the motor can still be checked for voltage?
If so, would this be the right thing to use?
Thanks
Old 01-15-16, 10:03 AM
I ended up buying a new motor (~$75) and installed it within 15 minutes. Everything is working great, thanks for your help
Old 01-15-16, 10:21 AM
I'm sorry I missed your previous post. You asked if you could check for 120v with the unit unplugged. No.... I recommend disassembly with the unit unplugged so that nothing is shorted or touched during dis-assembly. You'd have to plug the unit back in to check for power.
Glad to see your back in business.
HTML code is On
