What am I missing here?
Old 01-23-16, 01:44 PM
E
Hello, purchased home 2 years ago still looks to be original gas furnace it is a Bryant 394GAD. Already had an Aprilaire 550 installed but I don't I think it stopped working before I purchased home. So far I have replaced the solenoid and also have a new transformer ready to go in (tried but still no success) so took it back out. Like other threads I've scoured through, my control panel does not have a HUM spot on board as well as no fuse. The old transformer was hooked up to EAC-1 & EAC-2. The problem I am having is that there is no power coming from the eac spots (checked with volt meter & the panel buttom depressed) System otherwise works fine, thermostat works furnace gets call for heat, ignites, fan runs. Is there something that I am doing wrong here or is there a chance that spot on my control board is no good?Name:  image.jpg
Size:  38.2 KB Name:  image.jpg
Old 01-23-16, 02:18 PM
F
Received 35 Votes on 27 Posts
The EAC (Electronic Air Cleaner) terminals are only energized when the room air blower is running. You will need to have the safety switch pressed in AND the blower running to check for power at the EAC terminals.
Old 01-23-16, 02:22 PM
E
Sorry should have clarified that in op. I have tested it with safety switch down, blower kicks on and still nothing...
Old 01-23-16, 02:35 PM
F
I would have to see a schematic of the circuit board to offer anything more.
Old 01-23-16, 07:06 PM
E
Looks like theres a part number at the top of the circuit board reads: ceso 110018-00
Not sure of where to find correct diagram but digging into that now..
Old 01-23-16, 07:42 PM
E
Found this online but I think it matches up to what I have
Old 01-23-16, 08:29 PM
Received 1,114 Votes on 1,034 Posts
EAC 1 is the switched 120vac terminal and EAC 2 is the neutral terminal.
The EAC terminals are energized in heat and A/C mode.
Did you have your meter set for AC ?
Old 01-23-16, 11:22 PM
E
There was something wrong with my meter. Retested and everything is getting correct voltage and working properly!!
HTML code is On
