Aprilaire 700M and Armstrong Ultra 80 furnance
Old 02-17-16, 06:04 AM
D
Greetings. I need some assistance with wiring my new humidifier. I have purchased an Aprilaire 700M and it is installed on a Armstrong Ultra 80 oil fired furnace. The furnace is approximately 25 years old.
I have completed all of the installation except for the wiring the humidistat and actual humidifier. I am not very good at reading schematics and am asking for detailed instructions to ensure I wire it correctly. I also have a transformer that came with the humidifer as well.
As a side note, I replaced an old Sears humidifier and it was wired directly to the fan blower motor. I understand that this will not work with the Aprilaire.
I have attached pictures of the furnace to provide a visual so hopefully someone can assist me. Thanks in advance.
Size:  15.8 KBName:  084.jpg
Size:  41.6 KBName:  085.jpg
Size:  43.2 KBName:  086.jpg
Size:  48.7 KBName:  087.jpg
Size:  49.0 KBName:  088.jpg
Size:  43.3 KBName:  089.jpg
Size:  37.3 KBName:  090.jpg
Old 02-17-16, 02:34 PM
Received 3,740 Upvotes on 3,356 Posts
Welcome to the forums.
How was your Sears unit wired..... with a transformer ?
You have a basic heating system with no control board. The only way to connect your humidifier is to use a current sense relay like the model 50.
Aprilaire-50-Sensing-Relay-24-volt/dp/B002T0ZTNC
Old 02-17-16, 04:31 PM
D
the Sears was connected directly with the blower motor. 110v as far as I know. Is there anyway to use the transformer that was included with it to connect it? thanks for the reply.
Old 02-17-16, 05:54 PM
You can connect the supplied transformer to the blower motor.
Otherwise you'll need to supply the new transformer with power and use the #50 switching relay.
Old 02-17-16, 06:20 PM
D
Ok, so i connect the hot and neutral from the blower to the transformer and then I hook the white and black from the transformer to what? Sorry if I am being too naive.
Old 02-17-16, 06:46 PM
No problem....
Since the wiring between the transformer, humidistat and humidifier is AC.... there is no polarity.
Old 02-17-16, 07:26 PM
D
Awesome. thanks for the drawing it really helps. I will connect it in the morning. Thanks again!
Old 02-18-16, 07:16 AM
D
Well that didn't work. Just burned up the transformer.
Old 02-18-16, 09:55 AM
The wiring diagram is correct. I'm not sure what happened there.
Was something shorted on the 24v side ?
Old 02-18-16, 11:23 AM
D
Wired it per the diagram, and when the blower kicked on the transformer smoked and arced. Not sure what else to do.
Old 02-18-16, 11:25 AM
That sounds like the voltage was higher than 120v applied to the transformer. Usually an oil fired furnace will use a 120v blower motor but maybe yours is different. It will need to be checked.
