HC 35 Lennox Steam Humidifier
Old 03-25-16, 12:04 PM
H
My humidifier continuously refills without producing steam.
I have tried resetting it as per the instructions, the water empties and refills, the amp indicator augments till 3 amps, then the water re-empties and refills again but no steam is produced.
The display sometimes shows the code E8 which is foam detected, to which I have run various cleaning cycles but still no change in its operation.
Any help with this will be greatly appreciated
Thanks
Old 03-25-16, 12:53 PM
Received 4,051 Upvotes on 3,634 Posts
I'm not real familiar with your steam humidifier but at 3A it definitely won't be producing much steam. It may be caused by a mineral buildup between the heating electrodes. Have you inspected the electrodes ?
My forum partner, Houston, may be more familiar with it.
Old 03-25-16, 01:39 PM
H
Thanks for your reply. The electrodes are in the cylinder and I'm wondering if I can open the cylinder without causing damage to it.
Old 03-25-16, 04:13 PM
No.... it appears the cylinder is not a repairable item. I'm looking into it further.
