What causes dehumidifier to ice up?
Old 07-18-16, 09:12 AM
G
Received 1 Upvote on 1 Post
One of the 2 units running in my cottage basement is icing up. Coils are clean & there's good air flow around it. Seems to cycle on & off correctly (compared to the one with no problem). I noticed when I removed the catch basin to clean it. Once the ice melted I found the temperature probe had popped off the evaporator so I thought that was the culprit but it still iced up after pressing the probe back into place.
Old 07-18-16, 09:22 AM
Received 3,410 Upvotes on 3,059 Posts
The incoming air is too cold or loss of refrigerant can cause the evaporator coil to ice up.
The temperature sensor is usually positioned very close to the evap coil so if ice builds up it will shut off to defrost.
Make sure the filter is clean.
Try turning the humidity level setting up slightly.
Old 07-20-16, 06:55 AM
G
OK so if everything is clean and it's in a normal environment with average air temperatures surrounding it...is it unusual for it to be low in refrigerant and not show any signs of a leak (oily spot, corrosion, etc)?
Old 07-20-16, 09:03 AM
Not at all. There is only a small bit of oil and it doesn't leave the compressor.
