Aprilaire 600 automatic wiring to Carrier 59TP6 furnace - Need Check
Old 09-16-16, 08:56 PM
H
Hello,
I am installing an Aprilaire 600 automatic humidifier to Carrier Performance 96 furnace. Can someone please help me with the wiring or check if this is correct?
Humidistat: Furnace: Solenoid (Humidifier):
R -------------------------R
C--------------------------COM 24V------------------------S
W-------------------------W/W1
gf (not used)
G (not used)
H--------------------------HUM 24V
H------------------------------------------------------------S
ODT---outdoor sensor
Can you please check if this is correct.
Thank-you
Old 09-16-16, 09:12 PM
H
or should it be like this:
Humidistat: Furnace: Solenoid:
Gf (not used)
G (not used)
H--------------------------COM 24V
HUM 24V------------------------S
Old 09-16-16, 09:36 PM
Received 1,104 Votes on 1,024 Posts
Welcome to the forums.
This method will work.....
gf (not used)
G (not used)
An alternate way it can be connected if your thermostat is set up for two stage heat. ......
W------------------------- HUM 24V
gf (not used)
G (not used)
H-------------------------- R (jump to R)
Old 09-17-16, 10:32 PM
H
Thank you so much
Is there an appreciation button?
Old 09-17-16, 10:47 PM
Nope.... the thanks is appreciated. Good luck.
Old 10-07-16, 06:55 PM
H
Thank-you PJMax for your help.
I installed the humidifier today and everything works fine.
The first method that you mentioned was the one I used.
Old 10-07-16, 07:40 PM
Thank you for stopping back and letting me know how it worked out.
HTML code is On
