Nest 3rd Gen: humidifier connection
Old 10-20-16, 05:35 PM
R
Running Payne system and conversion to Nest 3rd Gen is straight forward. (i've converted a few to Nest in friend's homes). However this Payne system has a separate 2 wire Humidstat (Carrier box). Its a fairly old school and standard Model 884021B Humidity Controller (DNAGroup.com) 120/240VAC. I've attached pictures of the humidistat and the back of the current thermostat. Welcome any advice on connecting the humidifier control into the new Nest - not clear if i can run direct or if I need to install a relay.
Name:  2016-10-19 10.00.02.jpg
Size:  27.5 KBName:  2016-10-19 09.59.33.jpg
Size:  22.0 KBName:  2016-10-19 09.59.45.jpg
Size:  11.4 KBName:  2016-10-19 18.00.44.jpg
Old 10-20-16, 06:28 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forum.
I moved you to your own thread.
Your pictures are nice but not very helpful. It looks like you have a standard two wire thermostat but you left no info on what's powering the humidifier or what humidifier you're using.
HTML code is On
