Aprilaire 700 not working
Old 11-19-16, 02:54 PM
B
I have an aprilaire 700 model, with a manual control, no outside sensor. It is almond colored. I went to replace the filter pad this fall and it was still brand new, so it didn't work last year either. It was dry in the house, I didn't even think to check the humidifier.
I bought a little temp and humidity meter and it shows 40% inside the house, and the humidistat is set to 45%. When I go to test mode the green light flashes, water flows and the fan runs.
There are two sets of wires running to the humidistat, one comes off a transformer inside the furnace, (a very old Rheem), the humidistat is getting 28v with the furnace on. There is another pair of wires that run to the humidifier. Any help would be appreciated. Thanks.
Old 11-19-16, 03:54 PM
Received 1,114 Votes on 1,034 Posts
The almond colored 700 has its own transformer and does not require a second one.
Does the unit plug into a 120v receptacle ?
Old 11-19-16, 04:05 PM
B
It does. There is a cord coming out of the humidifier unit that goes to a 110 outlet. But there also is a transformer (i think) inside the furnace that feeds the humiditstat.
HTML code is On
