Aprilaire 560 to Nest - - - Three Zone System EWC NCM-300
Old 01-06-17, 08:30 PM
A
Humidifier: Aprilaire 560
Furnace: Bryant Plus 90i Gas
Thermostat: Nest 3rd Gen
Zone Panel: NCM-300
Hello Everyone,
I'm wondering what I'll need to do to get my humidifier hooked up to use with my Nest. I've read different places that I may or may not need a relay so I thought I'd post my setup and see what anyone thinks as I am pretty new to this. My humidistat had 2 wires when I removed it which brought me to trying to figure this out.
Thanks for the help.
Old 01-06-17, 08:57 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
You could use a relay but I'm pretty sure that zone controller is 40va which should be able to handle the load of the humidifier.
Do you have an extra wire to the thermostat ?
You will need to connect one yellow wire from the solenoid to C on the zone control board.
The other yellow wire goes to the * terminal on the nest.
Old 01-06-17, 09:28 PM
A
Thanks for the fast response! I'm not entirely sure where the yellow wires run to from the solenoid?At the Nest I have the red and white from the prior humidistat as well as an unused blue wire.
Old 01-06-17, 10:20 PM
Then you will be playing sleuth this weekend locating the wiring.
If you can't find where it's connected..... disconnect it and cap it off and run new.
Old 01-07-17, 10:31 AM
A
Ok, one of the yellow wires runs to the furnace with the white going to C and the red to HUM. The other runs to the transformer on the wall. Are you saying I should run the one to the zone control board instead of the furnace?
What wire would I use in the * spot up at the Nest on the main floor? White or Red?
Old 01-07-17, 10:36 AM
The humidifier needs a C connection that is the same as the thermostat. If there is a wire from C on the zone board to C on the furnace..... then your C to the humidifier is good.
The other yellow wire needs to get to the * nest terminal with nothing in between.
The color makes no difference.
You no longer need the transformer or the HUM connection.
Old 01-07-17, 11:07 AM
A
Ok, I think I get it now.
So I can just basically run a wire from one yellow wire to C on the zone board and run another wire from the second yellow wire to the spare blue wire I have for that zone, then i could just use the spare blue at the nest in the * spot.
Does this sound correct?
Old 01-07-17, 11:23 AM
That sounds like it should do it.
HTML code is On
