Aprilaire 600M installation with no HUM terminal
Old 01-18-17, 04:50 PM
E
I recently purchased an Aprilaire 600M but I have been struggling to figure out how to wire it into my HVAC unit to only operate only on a call for heat. My air handler is a Trane 2/4TEC3F60B1000A and doesn't have HUM or EAC terminal, that I can find. Will I be relegated to ordering the current sensing relay for the blower or is there another way? I uploaded a pic of the main wiring box inside the air handler cabinet.
Old 01-18-17, 05:06 PM
Received 1,105 Votes on 1,025 Posts
Welcome to the forums.
There us usually not an EAC or HUM terminal on a heat pump system.
Your system can have two calls for heat. Just the heat pump or the electric heat coils.
You have a G green fan wire. You can use that to run the humidifier.
You would connect to the G wire and the B/C connection. The humidistat would be in one of the lines. You would have to turn the h'stat all the way down in the summer to keep the solenoid from being operated.
Old 01-19-17, 12:01 PM
E
Thanks Pete! I guess I should have mentioned it was a heat pump. I presume B/C would be ground to complete the 24v circuit?
Old 01-19-17, 12:20 PM
The blue wire on the terminal strip would be your common to the transformer.
HTML code is On
