Aprilaire 600m Wiring
Hi All, I am trying to figure out how to wire my Aprilaire 600M. I have looked over all of the various wiring diagrams, but non of them seem to fit my situation. Attached is an image of what I thought would work, but apparently not. The idea was to get the humidifier to turn on when a call for heat is made and the humidifier sensed I needed more humidity.
That is kinda what I thought would be how I should set this up. The HVAC (electric heatpump) unit is a Trane.
I have a Trane Comfortlink II thermostat with the humidifier function, is it possible to use that to control the aprilaire 600m? I planned on using the manual control that came with the unit initially just to get it working. but if you guys think hooking up to the Comfortlink would be just as easy/hard, I would be willing to try that. The image is what the board in my Trane unit has as well.
Welcome to the forums.
It won't work as you wired. The W's are input terminals.
Technically you need a current sensing switch that clip on the blower motor wiring.
I see in your picture..... red is on R, blue is on B, what letter is green on ?
Aprilaire-50-Sensing-Relay-24-volt/dp/B002T0ZTNC
Green is on D which reads as 12 vdc.
So I am thinking I might be able to skip the manual control, although if I did go the manual rout I think I would just buy the current sensing switch. I did a little more investigating and came across the a panel I had not noticed before.
Can I use the HUM terminal to attach directly to my Humidifier? Also a pic of all the wires going to my board from the thermostat (with humidistat functions), heatpump and water drain pump.
link for better quality
https://drive.google.com/file/d/0Bxq...ew?usp=sharing
Would this work?
Just tie in the blue and red with the respective thermostat wire nuts shown in the earlier pics?
Not sure about the comfortlink II terminals.
i have an aprilaire 600a and the controller says 36% no matter what i do or turn the dial too. This is the automatic version with the humidistat outside. If i turn the controller to manual it will open the solenoid for water, but it does not seem to be working otherwise unless i turn the dial far right to test it. I bought a new humidistat for the outdoors, but to no avail. Can someone help?
thanks
thanks
