Humidifier solenoid not turning off
I posted about this months back but have finally gotten back to working on it and did not resolve my issue before.
I followed this diagram to hook my humidifier up to the nest.
I have also included pictures of my furnace wiring diagram and circuit board.
My issue is, even now in summer when my AC is on the Humidifier is running.
Do I have it wired incorrectly?
Any thoughts or suggestions to diagnose the problem?
Thank you for any help
When you disconnect one of the wires AT the solenoid.... the system stops ?
Your wiring is correct and would mean that the nest is calling for humidity.
You can confirm that by disconnecting the * wire to the nest.
You can run it to R. Either way.
The nest still has to tell the relay to close so the R to HUM connections has no effect on that.
