Nest 3rd Gen + Aprilaire 600: Only Working During Test
Old 11-03-17, 08:08 PM
N
I've been running a 3rd Gen Nest for a few months and recently installed an Aprilaire 600 humidifier. The wiring is per the attached diagram.
Under the Nest humidifier setup the following options are selected:
Type: Humidifier
Activate: Hum. + heat
Fan: Activate
When I use the testing function (SETTINGS > EQUIPMENT > CONTINUE > TEST) on the Nest for the humidifier it works as expected, the heat & fan comes on and water starts to flow out of the drain tube. However during normal thermostat operation when the temperature drops below the set point and the heat & fan comes on the humidifier solenoid is not opening and there is no water flowing out of the drain tube.
Any ideas why it would be working during testing but not during normal operation?
Old 11-04-17, 05:39 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
I recognize that diagram. I see my diagrams all over the net.
Ok.... where did you set the humidity setting ?
Old 11-08-17, 07:15 PM
N
Your question led me to the answer.
I assumed that the setting on the Nest would start the humidifier every time there is a call to the furnace for heat, regardless of what the thermostat sees for the humidity level.
I cranked the humidity setting up and all is working as expected. The default humidity level is just not high enough to kick in the humidifier since we are not into the cold and dry winter season yet.
Thanks for the help and the wiring diagrams.
Old 11-08-17, 07:19 PM
You are very welcome.........
HTML code is On
