Correct Solenoid Orifice Color for Lennox WB2-12 and WB2-17 Humidifiers
Old 11-05-17, 01:04 PM
2
Thought the solenoid valve was bad, but I'm thinking it is just the orifice. One orifice is white, the other is red. I'm only seeing yellow and white available on-line. Does the color of the orifice have anything to do with flow rate? If I can't find the red orifice, what color should I get (if color determines flow rate)
Old 11-05-17, 04:03 PM
Received 1,103 Votes on 1,023 Posts
The correct water flow is determined by an orifice in each unit. When the unit is operating, there will be a small, steady stream of water to drain, which flushes away most of the trouble-causing minerals.
I have never had to replace an orifice in a humidifier before. They do not go bad. You take it out, clean it and out it back in. I have no idea what color is supposed to be in it as I've never had to mess with exchanging one.
If your calls for a red one...... this would be it.......
appliance factory parts/part/276018/108905/
HTML code is On
