Ecobee4, Stat and Humidifier rewiring check
Old 12-25-17, 08:52 PM
B
Hello All,
Just purchased ecobee4 and trying to figure out how to integrate it in the place of the old Stat. After reading this thread i think i figured it out but wanted to run by the pros here to see if it makes sense. Thanks.
Old 12-25-17, 09:14 PM
Received 1,114 Votes on 1,034 Posts
Welcome to the forums.
Since you've got an Ecobee 4 you're in your own thread now.
Excellent diagrams...... should work fine.
My diagram shows using Rc.... although either should work.
Old 12-25-17, 10:37 PM
A
Received 44 Votes on 39 Posts
Be careful as with the Ecobee 4 and a PEK the wiring is strange at the thermostat. The old G goes to C with the old Y going to the PEK terminal. And they recommend the R going to Rc
Old 12-26-17, 12:34 AM
B
Thank you both. Updated diag attached.
There is one concern however. On another forum I have read that e3 paired with Skuttle 2000 Humidifier blows out 3A fuse on the furnace board drawing too much power for that fuse. I have that same fuse so likely I will have to get 120->24V transformer and run Humidifier on external power vs supplied from the board. Any thoughts?
Old 12-26-17, 01:28 AM
The Skuttle solenoid requires 7.5va from the transformer. If you want to run the Skuttle on its own transformer then you will also need a relay to convert the ACC+ signal for relay use.
Old 12-27-17, 08:26 AM
B
Wired yesterday morning, so far so good running off of the furnace's 24v. Will update if there are any issues. Thanks.
HTML code is On
