Thermostat triggering fan when humidity is low
Old 03-09-18, 09:02 PM
Hello,
When my thermostat detects that the humidity is low it is turning my furnace fan and my humidifer on.
I only want the humidifier to turn on when the heat is running.
Is is there a way for me to change the wiring at the thermostat to change this (see attached picture - z terminal is humidity) or do I need to investigate how itís wired to the furnace as well?
https://photos.app.goo.gl/RaiA2rfzDDwQtDmm1
Its a bit of an obscure thermostat - Adct-2000 - it doesnít have the option in app to choose the preferred mode (ie heat or heat and fan) for humidifier like the nest or Ecobee
thanks!
-Sean
Old 03-09-18, 09:31 PM
Received 1,118 Votes on 1,038 Posts
Welcome to the forums.
Follow this for future pictures.... How-to-insert-pictures
Looks like you have an A/C system and possible a separate furnace. I see an Rc and Rh wire which says you have two independent systems.
The thermostat doesn't look like it can control a humidifier. That means you have a humidistat somewhere.... probably on the furnace return..... that controls the humidifier and the blower. I need to see that and it's wiring.
Building36/uploads/2016/01/Intelligent-Thermostat_Product_Manual.pdf
Old 03-10-18, 07:35 AM
Sorry about the original attachment method.
They've updated the firmware now for this thermostat to control humidity from the z terminal. It buries it on page 9 of this updated document: "Z can be used for W3, H, or DH." (https://d10k7k7mywg42z.cloudfront.ne...ADC_T2000_.pdf)
Correct that I have AC and Heating. To my understanding the AC has it's own power separate from the furnace which is why i have both an RC and RH connection at the thermostat.
Let me know if these pictures aren't good enough:
Picture #1 - Two black wires come off the solenoid at the humidfier
Picture# 2 - One goes to C at the Furnace, the other goes to Z at the thermostat
Picture #3 and #4 - wires at the furnace
See previous post for wires at the thermostat
After reading around on this forum I believe that if I move the black wire from C at the furnace over to W1 then the humidifier should only come on if stage 1 heat is on. Am I on the right track?
Thanks for taking the time and I really appreciate the help.
Old 03-10-18, 08:06 AM
Unfortunately there is nothing that can be changed by rewiring. If the stat turns the heat or fan on when humidity is required.... that is strictly a function of the thermostat. Even if you disconnect the humidifier.... the heat/fan would still start.
There is little to no technical support online for that thermostat in regards to specialized settings.
Old 03-10-18, 08:21 AM
Interesting... if I wire the humidifier to the humidistat that comes with the GeneralAire 1042 LH is the current wiring at the furnace setup correctly? Or if I swap out for an ecobee4?
Old 03-10-18, 08:31 AM
You could use C and W1 to supply a separate humidistat.
The ecobee 4 has multiple configurations.
Old 03-10-18, 11:15 AM
Upon further review it just seems to be running the humidifier when the fan or heat is on - itís not turning the fan on when it needs humidity like I originally suspected. Does this change things ?
Old 03-10-18, 11:41 AM
It sounds like it's operating when it should be. You should be all set.
HTML code is On
