Dehumidifier Not Collecting Water
Old 10-02-18, 05:28 PM
G
Hello everybody,
I've an hold dehumidifier, it's stopped to collect water.
I've checked a couple of things before writing this post :
  • I've changed the capacitor
  • The compressor is ok, i've tested the 3 pins.
When I start my dehumidifier, the blower start, the sensor give the correct humidity value. But the compressor stay silent.
One fact to notice, when I changed the capacitor, the first time I ve restarted the humidifer, the compressor has started. I shutdown the power, and now nothing happens with the compressor.
I've noticed that when it's plugged, I've no electricity coming in the compressor wire (see my picture attached).
I think the problem is coming from the circuit (may be the black square is out, don't know what kind of component it is).
What do you think of my conclusion ? Is there a way to repair it ?
Every help will be appreciate.
Thanks
Cyrille
PS : I apologize for any grammar errors
Old 10-02-18, 06:06 PM
Received 1,118 Votes on 1,038 Posts
Welcome to the forums.
K1 is the compressor relay. You have power going to it but not leaving it. That means 1 of 2 problems.
1) the relay is not closing.
2) the relay is closing but is defective/burned.
You can carefully short those two terminal to see if compressor works properly. I would use a piece of wire with alligator clips. You can use an insulated handled screwdriver. Hold it on there carefully. You may see a spark which is normal.
Old 10-04-18, 04:10 PM
G
Hi Pete,
Thanks for your input.
I'll try that , carefully
Cyrille
Old 10-08-18, 04:34 PM
G
Hi,
I've tried to bypass, but when I plugged there s a shortcut and the wire is burning
Is it normal ?
Regards
Old 10-08-18, 04:39 PM
G
My bypass
Here's my bypass
Is it correct ?
HTML code is On
