Nest 3.0 with Aprilaire 600
Old 11-04-18, 08:42 AM
Hi, I'm new on these forums, and I've read a number of the posts on humidifiers with Nests. We recently purchased a house with a humidifier installed but unwired. I have wired a Nest thermostat to the furnace, which is a Lennox G60UHV(X), and wired the Aprilaire 600 humidifier to the Nest following the diagram below. Everything seems to be working correctly. I'm a little confused about the need for a relay though. I have a White Rogers 90-290Q relay on hand, would it hurt to add that in? Thanks for any help!
Matt
Old 11-04-18, 08:48 AM
Received 1,104 Votes on 1,024 Posts
Welcome to the forums.
Your installation is wired correctly.
A relay is only needed if your humidifier had its own built in 24vac transformer. Yours does not.
(keep the relay in stock for the future)
Old 11-04-18, 02:22 PM
Oh great, thank you for the quick response!
HTML code is On
