Installing Humidifier - a few Questions
Old 11-08-18, 08:28 PM
P
Received 2 Votes on 2 Posts
Installing Aprilaire 500 and I have a few questions:
1. The best place on my supply would be just inches above the cooling coil....in fact the top of the coil would probably be at the same level as the lower part of the cut-out for the humidifier - is that OK?
I red that the humidifier must not obstruct the air flow around the coil but the way I see it - it shouldn't...since it is not really sticking to the inside and the coil is shaped like a triangle...so the tip of it is narrow with plenty of flow all around...
2. The external temp. probe has a short AWG22 wire....can I extend that using AWG18 wire?? I don't have anything smaller on hand ...but if I shouldn't mix the different gauges then I will pick up some 22 for the probe
I think that's it...for now
Thanks !
HTML code is On
